After Chuck and I kicked emails back and forth, we finally got to speak on the phone for a brief spell and he explained this project to me in greater depth. It seems that his flying buddy, Richard Stultz, also shares an interest in Old Timer designs, having built the original Lanzo Bomber from Chet Lanzo's plans. Richard captured the beauty of this plane in foam after scaling it down 50% and building one from 6mm Depron (pictured below). Chuck and Richard both told me that the plane, with a 1300kv Blue Wonder, flies incredibly like the original! It's really hard to believe that a little Blue Wonder can power up a larger aircraft like this, but they have assured me that it does so with ease.
Last week I got a phone call from Richard so that he could explain the aircraft in a little more depth. It turns out that Richard has been playing the RC game for quite some time, and in addition to the RC hobby that he and I share, he's also an avid motorcyclist! In the package he sent to me, he included a picture of his BEAUTIFUL Honda Valkyrie! LOL Chuck, I envy you for having such an interesting and capable flying buddy!
Anyway, Richard sent me a very comprehensive set of drawings that he had worked up along with a CD full of images from their original foam Lanzo Bomber. From these materials I was able to work up the files that are attached here. Had it not been for the completeness of his materials, I would have had significant difficulty working this project up! Got any more cool stuff for me to work on for you, Rich?
With a sizable scale drawing in hand, I set out to recreate this plane. Now the question arose "How in the world am I gonna get this in SketchUp?". EASY! I took his posterboard drawing and figured out how many times I might need to scan this thing on my trusty old Dell 310 scanner/printer. I then drew tic marks and scales on the drawing in several places and scanned the thing in segments making certain to capture the tics and scales in each scan. I was then able to import each one into it's own SketchUP document and scale it to the proper size. Once I had all of these separate SketchUP files completed, I started copying and pasting them into a single SketchUP file where I could assemble them (one for the Fuse, one for the wing, and one for the horizontal). After the hard work was all done, then the fun and easy stuff started - redrawing all of the parts.
I actually surprised myself on this project. From start to finish, this project only took about 2 hours to complete, including the time to draw the tics and scales and scan the drawing!
Chuck advised that he has some difficulty in running FFF on his MKII (bummer), so he prefers 6mm Depron. He asked that I lay the parts out to compliment sizes available for that material and I was able to accommodate him without any problem. Our buddies over at RCFoam sell 6mm Depron in sizes of 13" x 39" in White and 15" x 39" in Gray. I figured it best to lay the parts out to the smaller size so as to not limit his processing the files to Gray Depron only.
So here we have it - the fruits of my labor and fun! The design will require you to use 3 sheets of 6mm Depron no less that 13" x 39" (34" cut length on the X axis). The PhlatCodes allow for 100 IPM feedrate (my preferred speed when cutting Depron), V-Tabbing at 10% Depth, using the stock 1/8" PhlatBit. I can see no reason why you cannot cut this thing out on FFF, but that wavy substrate will lessen the beauty of this fine aircraft.
As is usual with my file packages, I have included my COMPLETE package including the scans, my rendering, PhlatCodes, and SketchUP files along with a picture of Chuck's finished plane. Please note that there is a large triangle also included in the parts - that is a polyhedral fixture to aide you in setting up the proper angle for the polyhedral wingtips (you'll have to sand in the angle on the tips before you glue it up). Oh yeah, one more thing - I have also tabbed and slotted the fuse-side braces so you can put them in straight the first time, as well as the mounting plate for the wing.
ITEMS NEEDED FOR COMPLETION
3/16" Dowel for joining the elevator halves
3/16" Dowel for the wing hold-down pegs
24" length of Carbon Fiber tube to brace the wing (butted against the Kf step)
1 3/4" square piece of ply (I suggest 3/16") for the motor mount
Tape for the hinges
#64 Rubber bands for the wing mounting
Your favorite glue
I'll let Chuck chime in on his preferred electronics and landing gear...
Chuck and Richard, thanks for including me on this great project! As soon as I get a fresh supply of Depron, I'll be cutting one out for myself! I think this is gonna be a hit with those folks looking for a relaxing Sunday flier.
Posts
