DOWNLOAD Mach3 Version 2_60 Here :)
Discussion in 'Mach3' started by kram242, Dec 7, 2008.
    Mach3 is a control software, it takes the Phlatcode(gcode) you create using the PhlatscripT in Sketchup and converts it into electrical pulses sent to your motors.
    This is a limited download of Mach3. It is the Full program, but only allows a limited amount of Phlatcode(gcode) to be processed therefore it will work on simple designs that only require 500 lines or less of the Phlatcode. It is a great way to get started cutting with the Phlatprinter.
    Once you decide to buy Mach3 you will receive a licence that will unlock the code limits and you can load as much Phlatcode (gcode) as you would like :)
    You can purchase Mach3 from Phlatboyz here: http://www.phlatboyz.com/phlatstore/#ecwid:category=146070&mode=product&product=297465
    Thank you for your support!
    This program will allow you to grow in CNC and we highly recommend it because we have tested and used it extensively for the price we feel it is the best control software out there at this time.
    We are running an older version of the Mach3 software (version R2_60) We find it to be stable and efficient for the Phlatprinter. There are however newer versions that have yet to be tested so feel free to download a newer release and let us know how it is working for you.
    As we move forward and test different versions we will be updating this to a newer release.
    Linked FTP download from the Mach Website ftp://anonymous:guest@machsupport.com/M ... nR2.60.exe
    Download Mach3 Version R2_60 here
    Direct Download
    Attached files Mach3VersionR2_60.zip (24.5 MB)Â
