Little weird problem
Discussion in 'General Talk Forum' started by Blackkrystal73, May 7, 2015.
  1. Blackkrystal73
    Blackkrystal73 New Member
    Neffs, Ohio
    Can someone take a look at these two files and tell me what I'm doing wrong? Look at the left side of the horizontal stab, see how the gcode is all messed up there. I've have deleted it and drawn it many times, that didn't help.
    I'm using the latest sketchup and sketucam 1.3. Any help is greatly appreciated..
    Kevin
    Attac
    Kevin, if this is the file that you work on too then one problem is that you didn't set the bit diameter in the parameter box. Try setting it to the bit size you're going to use and try again and let us know if you still have problems.
  3. Blackkrystal73
    Neffs, Ohio
    I set the size to .012 because I'll be using a drag knife to cut this. Is there a different setting I should use for a drag knife?
    Kevin
  4. swarfer
    first, set your model units to decimal inches with 3 decimal places of precision.
    format
    model info
    units
    format 'decimal'
    precision = 0.000"
    this will allow the parameters dialog to correctly display (and save) a 0.012" bit size
    then, you have somehow set the outlines of your parts to be cut lines. this is wrong, the outside and inside cut lines must be outside (or inside) the actual part outline (by half the bit diameter, bit diameter should never be 0).
    corrected file is attached
  5. Blackkrystal73
    Neffs, Ohio
    Thank you very much. These are the kinds of things that no one tells you about. lol
    Any chance in getting drag knife support in future updates. A lot of us are cutting Flitetest foam,(dollar tree foam, or Adams ready board)
    Thanks again
  6. swarfer
    yeah, work has started on dragknife code generation.
    in the meantime you can use the Donek tool
  7. swarfer
    Also watch this one (-:
  8. Blackkrystal73
    Neffs, Ohio
    Thats good information. I'm glad to hear your working on drag knife.
    I'm sure you have a ton of work in developing this. Thank you so very much. I appreciate it
    Kevin
