Reversing cut direction
Discussion in 'SketchUcam Help' started by Helno, Aug 28, 2011.
  1. Helno
    Helno Member
    This may be a stupid question but is there a way to reverse the direction of cut?
    I cut out a Piajet3d and had to sand all of the outside cut edges because on all of them the cut path moved so that the cuter ws rotating into the part instead of away.
    The scrap foam had great edges and all of the cut parts were covered in fuzz.
  2. Thewz
    Thewz Moderator
    Temecula, CA
    I think reversing the face of the part will do that.
  3. Jnida63
    Did you make sure overhead gantry option was selected before you output your code?
    If not it will cut backwards thinking the bit comes up from underneath
  4. Helno
    Helno Member
    I did not have it checked.
    Good to see that it was a simple answer.
  5. 2xWhiskey
    2xWhiskey New Member
    Gadzooks...
    I'm into day 3 on getting back into my PP3 after shelving it for about a year. This is one of the problems I've been having.
    Thank you for asking this before I did Helno, and thank you Jnida63 for the answer!
