Setting Z Coordinates !!
Discussion in 'Mach3' started by xtremeRCpilot, Jan 8, 2011.
  1. xtremeRCpilot
    Hey Guyz, I was wondering how I could set my Z coordinates in Mach3. I need to bring it up to a certain value -.9378
    and cant figure how to do this once the machine is up and running! I can use the jog but I have to bounce back and forth until I hit this exact number! Any help would be great!! :)
    thanks
  2. Flashsolutions
    Click on the MDI Alt2 tab and in the input box, type G1 Z-.9738 F10
  3. Anonymous
    Flashsolutions, is "G1 Z-.9738 F10" the entire text entry, followed by pressing the "Enter" key, or is the "F10" part performed by pressing the F10 key?
  4. Flashsolutions
    G1 is the command, Z xxx is the value (or Y xxx) for the Y axis, and F10 is the feedrate....
    You can substitute whatever feedrate you want... F20, F30, etc
    Then the Enter key to send the command
  5. Gefahren
    Gefahren Member
    you could also go to the same screen and just put z-0.9378 and hit enter, it will use whatever feed rate was last used.
  6. xtremeRCpilot
    Hey Guys, thank you for all your help!! Sorry for the delayed response but for some reason I dont get the email from the phlatforum when someone responds to my thread :( Either way I am grateful and will read back over your posts and see what works good!! :)
  7. xtremeRCpilot
    Thank you Flash, this works awesome!! What would be the code for the Y and X axis? :p
