SketchUp Video Tutorials
Discussion in 'Sketchup Tutorials' started by Crash, Dec 9, 2008.
  1. Crash
    I've worked up a series of tutorials for SketchUp as it pertains to the PhlatPrinter and CNC machines.
    Please note that I am, by no means, a "pro" at using SketchUp. This documentation is only to help those people that know a little less than I do about using this program. :) Hopefully, these tutorials will give you a little insight of how I work with this application to cut out files on my PhlatPrinter.
    Also please note that these videos utilized the PhlatScripT v904 PlugIn. When I get to it, I'll put together a video highlighting the capabilities of the new v910 PlugIn!
    PhlatPrinter SketchUp Basics - Part 1, File Organization And Creating Your Template
    [vimeo]http://www.vimeo.com/2271539[/vimeo]
    PhlatPrinter SketchUp Basics Part 2, Creating A Parts Layout Reference
    [vimeo]http://www.vimeo.com/2271577[/vimeo]
    PhlatPrinter SketchUp Basics Part 3, Using The PhlatScript PlugIn Part 1
    [vimeo]http://www.vimeo.com/2271723[/vimeo]
    PhlatPrinter SketchUp Basics Part 4, Using The PhlatScript PlugIn Part 2
    [vimeo]http://www.vimeo.com/2271755[/vimeo]
    PhlatPrinter SketchUp Basics Part 5, Generating PhlatCode
    [vimeo]http://www.vimeo.com/2271777[/vimeo]
    PhlatPrinter SketchUp Basics - Part 6, Importing DWG/DXF CAD Files
    [vimeo]http://www.vimeo.com/2291401[/vimeo]
    PhlatPrinter SketchUp Basics - Part 7, Cleaning Up The DWG/DXF CAD Import Part 1
    [vimeo]http://www.vimeo.com/2291427[/vimeo]
    PhlatPrinter SketchUp Basics - Part 8, Cleaning Up The DWG/DXF CAD Import Part 2
    [vimeo]http://www.vimeo.com/2291820[/vimeo]
    More to come!
  2. Crash
    Placeholder for subsequent videos...
  3. Anonymous
    Crash, I'll bet you have some sort of script you use to remind yourself of all the things to point out, eh? Could you post a copy of those scripts? That would make it a lot easier to find which video, where, mentioned something in particular.
    (I really hate re-watching 10 minutes of video just to find the spot where "this or that" was mentioned, only to find I've watched the wrong video again.) :x
  4. Crash
    I'm sorry, Dorsal. I have no script - that's the reason I sound like such an idiot doing these things! lol
    I could probably come up with some sort of outline, though. Give me a little time and I'll try to work up something for you. Be careful what you ask for, though - I have written many operation manuals and SOP's over the years, so what you end up getting may be more difficult to reference than sitting through the videos again! lol :shock:
    I kept the videos short so that reference at some later point would be less painful.
    Great job Crash thank you so much for taking the time to post these they are going to help out a lot of folks.
    Mark & Trish
    Here are mine to help
  6. Brandy
    Brandy New Member
    Thank you for making the videos here they were very helpful.
  7. Adomeo
    Adomeo New Member
    how do you get the 3 views into setchup when i try to move and rotate around it it just dissappears
    thanks
    Adam
    When you import an image in Sketchup make sure over to the right it is set as an image not a texture. I think this may be the reason they are disappearing on you?
  9. Adomeo
    Adomeo New Member
    still no luck, how can i actuarly import them
    (i've only been using the program a few days)
    Here's a 3 part tutorial that shows how to design and work up a full fuse style aircraft in sketchup
    Hope this helps someone
    PART-1
    PART-2
    PART-3
    yamajason likes this.
  12. kyyu
    Great tutorials, Mark! I learned a few things. I was amazed the components, can be scaled from the outside and not change the others. Had to test it out for myself. I notice one problem though. If you do the offset to one bulkhead, for the foam thickness, the offset won't be the same on each component if they are not all the same size.
  13. kram242
    Thank you Kwok,
    That's a good point about the resizing being different and that is where the pro version of Sketchup would shine using the dynamic components features. But I do not have that kind of dough :)
    I think you could go in and change each one but its such a small amount in this example that it would not make too much of a difference.
  14. Anonymous
    Nice tutorials Mark - I finally got a chance to watch them. :)
    Thank you Dennis :)
    I hope to make more and go into more depth with future tutorials now that I can break them up into 10 min sections
  16. kyyu
    Mark, have you seem the annotation features on youtube. I just tried them out today. I put 1 or 2 notes in my two phlatscript videos. In particular, I put a note at the end of the 1st, which when clicked is a link to the 2nd video.
  17. kram242
    I have seen them I used it once on the surfer dude build log video, but have not really messed with them too much more then for that one video. It is a great feature though especially if you forgot to mention something during the filming. They can be quite helpful
  18. Orion13
    Orion13 Member
    I really appreciate the videos. The only thing that keeps me from purchasing a cnc machine is getting the model I want into the PC. Now that I have watched these a few times I'm going to try and see if I can get a full fuse plane in. It may be a fact that you guys make it look easier then it really is. :eek:
    Orion13
  19. 3DMON
    I think your going about it the right way. Sketchup is the easiest cad program I've played with but there is a slight learning curve. The videos in this forum will help a lot. It gets easier the more times you use Sketchup. Welcome to the forum.
  20. kram242
    Orion13,
    Try learning a tool a night, find out everything you can about that tool in one session. Keep that up for a week and you will have it down. Here are some good videos to get you started as they go through the tools. http://sketchup.google.com/training/vid ... o_gsu.html
    If you run into any problems don't hesitate to asks, that's what we are here for :)
    Hope to see you in the PhlatClub soon.
  21. Mike Britton
    Mike Britton New Member
    Mark,
    Do you have a functional link for these videos?
    Mike
  22. kram242
    Whoops sorry Mike theses videos were left out of the new upgrade to the Phlatforum.
    I just added them back into the post above.
