Looking for parts Phlatprinter 3 #41
Discussion in 'General Phlatprinter 3 Chat' started by Learjets, Mar 9, 2017.
  1. Learjets
    Learjets New Member
    Lebanon, IN
    I was given kit #41, all unopened boxes. I am missing the small gear that goes on the X axis (roller stepper) stepper motor that drives the belt. Any idea of a P/N? or # of teeth, shaft size? and where I can order it!
    You should pm kram242 (the designer of the Phlatprinter).
    He should be able to give you the part#. He might even still have an extra.
  3. TigerPilot
    Learjets, if you are talking about the pulley that goes on the stepper motor, I took a look at mine and it looks like it's a 16 teeth pulley. They are very inexpensive. You may get one sent from China for less than $2.
    I believe it was mxl also not the typical g2 pulleys we normally see. The original pulley came from www.sdp-si.com
  5. Learjets
    Learjets New Member
    Lebanon, IN
    TigerPilot - is the stepper gear on the gantry the same as the roller stepper stepper?
  6. TigerPilot
    I can not recall if i changed my pulleys on the z axis or not. The ones I have now are 15 tooth and the one on the x axis stepper is 16 tooth.
    Get yourself a 15 tooth and a 16 tooth and use the one that fits best with the closed loop belt.
