Phlatprinter 3 Belts
Discussion in 'General Phlatprinter 3 Chat' started by zann68, Jul 7, 2013.
  1. zann68
    zann68 New Member
    New Brockton Alabama
    I had a accident with my machine and my belt that runs the rollers is damaged:nailbiting: . I need to know where I can get a replacement(s) ASAP
    Jeff
  2. foamlvr
    foamlvr Member
    northwest Ohio
  3. ewo
    You could also try emailing Mark and Trish
    Another source is Amazon. I had bought there belts for the z axis. I had paid something like $9 for three different belts, shipping included.
  5. Rowedent
    Rowedent Member
    I stretched out the roller drive belt (it should really be bigger I think) and had to replace it. Mark and Trish sent me one, but I also bought one direct...this was my email to Mark, he said that the link was pointing to the correct belt
    The X axis belt stretched between two of the teeth and is ready to break. Looking closely I see that all of the little threads are broken at that point.
    I have barely used the machine so I doubt that it was worn out, maybe I over tensioned it when I was trying to eliminate the belt jumping over the teeth and therefore missing steps.
    Can you send me a link to where I can get a replacement.
    is this the belt:
    https://sdp-si.com/eStore/PartDetail.asp?Opener=Cart&PartID=3512&GroupID=213&Qty=2
  7. zann68
    zann68 New Member
    Thanks everyone for the support! Got those belts ordered. Whats the part number for the Z-Axis belt may go ahead and have a spare stored just in case
    Thanks in Advance
    Jeff
    Good deal Jeff
    The Z and rollers are the same belt :)
  9. zann68
    zann68 New Member
    Great! Did not notice! Thanks everyone to coming to my help for pointing me in the right direction for my repair parts
    Jeff
  10. ToxicToast
    Thats good to see. I've been wanting to replace mine soon as preventative maint. Seems the heat and dry air here isn't that healthy for them long term.
  11. 3DMON
    Hey Mark do you have the part# for the small pulley? Mine let go recently and I replaced it with the one from my MK1 but I'd like to get a metal version of it.
  13. 3DMON
    Are you saying you have the all metal one in stock though?
  14. kram242
    Correct :) I did a double check with Trish just to be sure :D If you order the one from the store it will be the all metal pulley.
