RTD FFF quad
Discussion in 'Multi-copter/Helicopter Plans' started by Helno, Sep 12, 2012.
  1. Helno
    Helno Member
    I had a KK blackboard collecting dust after installing a KK 2.0 board on my tricopter so I decided to make a cheap simple quad.
    I used the following power system.
    Turnigy 2204 motors
    SimonK'd plush 6A esc's
    1000 mah 2S battery
    8x4.3 props
    The frame is made out of fan fold foam that I milled on my phlatprinter. It isn't strong but it is very light and easy to repair.
    Ready to fly weight is 266 grams.
    The small square bit is a power distribution board made out of some very thin copper clad glued onto a piece of 1/32 plywood. Attached files quad.skp (166.7 KB)Â
    266 grams! Thats is an awesome use of fanfold awesome :doubleup:
    Great job on this Helno and thank you for sharing
  3. arkcom
    arkcom New Member
    Did you paint over your distro board? Drop a screw or paper clip on there and it might go up in smoke.
    Thats a good tip arkcom a good coat of paint/epoxy over that is not a bad idea
  5. Helno
    Helno Member
    It does have a thin coat of ca glue over it. This guy runs on only 2 cells and the only screws are holding the motors on.
    Next up is to make a prop shroud for indoor flying.
  6. mavacpjm71
    mavacpjm71 New Member
    Really nice Heino!!! :D Thanks for sharing....
  7. 66tbird
    Nice.
  8. Helno
    Helno Member
